I understand that ServiceNow has a side door function/feature that can bypass SSO. Does anyone know how we can activate the side_door.do feature with a local account?
Gregory
I understand that ServiceNow has a side door function/feature that can bypass SSO. Does anyone know how we can activate the side_door.do feature with a local account? The user/tester will have the ability to login through entering the “TestUser” user name and password.
  1. Currently - we cannot sign on in our Dev instance and QA instance with local accounts (TestUser) because of SSO.
  2. We tried the Side_Door.do.
    1. Doesn’t work.
  3. What configurations might be stopping it?
  4. Does anyone have any ideas on how we can bypass SSO in in our Dev and QA instance?
Brandon Warren
As stated above, you should be able to use https://instancename.service-now.com/login.do
*Note, you may have to set a password on the user account you plan to sign in with beforehand. See image below.
i m trying to create my custom side door url but still redirecting to login.do .is there anyway i can get login page ui on side door url?
pablodely
Is there a side_door feature/setting that will allow you to be prompt to login at the Service Portal login page when SSO is enabled?
Hello Pablo,
normally OOB there is the "side_door.do" set up. ([your instance URL]/side_door.do)
But there the password on the user record must set up first.
wabexele
Mega Contributor
The ServiceNow side door function allows users to bypass Single Sign-On (SSO) for access, which can be useful in specific scenarios. To activate the side_door.do feature using a local account, administrators typically need to ensure that the appropriate permissions are set and that the feature is enabled in the system configuration. For those looking to implement similar access solutions, it’s important to consider security implications and follow best practices. Meanwhile, if you need reliable doors installers in Palm Coast, there are several professionals available who can assist with various installation needs while ensuring quality and efficiency.
