01-20-2022 10:47 PM
My requirement is based on selection of choice few fields should appear for each different choice value.
So i created 4 catalog ui policies for each choice value in record producer. to hide not required form fields and gave different orders.
on selecting choice based on order it runs perfectly , but if i do reverse selection Ui policy not working,and showing all fields without hiding other fields that were given in ui action.
Can u please suggest how to resolve this
regards,
Kalyani
Service Catalog
01-20-2022 11:04 PM
have you done this?
For one choice field, In UI policy actions Make wanted fields visible and unwanted fields hidden
do the same for the rest of the options and uncheck "Reverse if false" also, make sure your UI policy order is correct
01-20-2022 10:58 PM
Hi Kalyani
can you share the screenshots of your UI Policies?
I generally will write a onChange client script instead of multiple UI policies which conflict with each other unless properly configured.
01-20-2022 11:07 PM
