Need help regarding a requirement. On Applications(cmdb_ci_appl) table we want to have a field called Security role as a drop down(not unique for all applications) with different values.Each Application will have different security roles and we want
09-16-2020 01:03 AM
Need urgent help regarding a requirement. On Applications (cmdb_ci_appl) table we want to have a field called Security role as a drop down(drop down values will not be unique for all applications) with different values. Each Application will have different security roles and we want to display these security roles on a catalog item form when an application (referenced to Application field on cmdb_ci_appl table) is selected.
Example application and their respective security roles as below. When Application is selected as 'Active Directory' on catalog form relevant security roles to be displayed under 'Security Role' field.
My question is how to populate 'Security Roles' for applications on cmdb_ci_appl table, once this data is sorted I can easily bring them on catalog form by referencing fields to cmdb_ci_appl table. Sicne the security roles are not unique for the applications, how do I populate them? Do I need to have another table to maintain these Security roles, if yes how can I populate them on cmdb_ci_appl table.
Anyone please through some light on this requirement.
Thank you!
09-13-2021 02:01 AM
Hope you are doing good.
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
09-24-2020 12:25 AM
Sorry Ankur! It's not in my PDI
09-24-2020 12:32 AM
No worries
Did you check with admin user if they can see the data in 2nd reference variable?
Also did you check my previous comment
09-29-2020 10:52 PM
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
If not, please let us know if you need some more assistance.
