Need help to understand scoped application and extending current OOTB table for scoped application
10-27-2025 02:01 AM
Hello All,
I need your expert advice about creation of scoped application. But as per the requirement i need to extend cmdb_ci table to be part of this scoped application. Do you see any risk in this approach? Also what are the things i need to consider while creating custom table that needs to be extended from cmdb_ci.
Thank you.
10-27-2025 02:11 AM
yes you can extend cmdb_ci in your scoped application.
Remember your scoped app might require different behavior/access controls etc on that extended child table.
but since it's extending cmdb_ci, the ACLs (table level and field level), client scripts, UI policies etc will be inherited.
You will have to ensure you override those as per your requirement.
Few best practices
-> only create those fields on your custom table which are required and you can utilize the fields coming from parent
-> don't override default relationship types (cmdb_rel_type). Work within defined CI relationships
-> use dictionary overrides for your custom behavior
10-27-2025 10:33 PM
02-24-2026 02:02 AM
Hope you are doing good.
