Need help with workflow script if condition
ven1
I need to define the workflow for 'if' condition when user selected "Yes" or "No"
Example : If user needs PC and he/she selects "YES" workflow goes to next level and selected "NO" workflow has to completed.
Can any one help me for the workflow and script.
Thank you.
snowtech1
Hello Venkat,
I'm not sure you need to define any block.
You could use the OOB 'if' block in wf editor and I understand it's a catalog item, so in the script block something like,
if(current.variables.variable_name=='yes')
return 'yes';
else
return 'no';
Then branch out the yes/no on the 'if' block
