no_text_index=true on knowledge article body
davidsmith
I understand the you can add a setting of no_text_index=true to stop a field being searchable by the legacy search (Zing?).
In the article body fleld of our knowledge articles we have a dictionary entry with a default value of no_text_index=true. This is value also in the attributes list. Can we safely remove this from the default value? We need to put a new vaule in the default value, plus we no longer suer Zing.
Thanks in advance.
David
HemanthGollangi
Giga Guru
yes, it should be safe to remove no_text_index=true from the Default value if it is also present correctly in Attributes. You do not need to remove it from Attributes just to use a new Default value.
HemanthGollangi
Giga Guru
Thank you so much for the confirmation.
David
