prerequisites for integration hub implementation ServiceNow
Raja27
I need to implement Integration hub can you help me on the prerequisites.
Thanks in Advance!!
Hi Raja,
Integration hub requires a subscription for production instances but can be activated on non-production and personal developer instances to build and test integrations without a subscription by activating a plug-in. The ServiceNow IntegrationHub Installer plugin activates a suite of plugins and takes about ten minutes to activate. You will receive an email from the Developer Portal when your plugin activation is complete. Once the plugin is activated, you can follow through the section to build your first spoke:
https://developer.servicenow.com/connect.do#!/event/knowledge2020/CCW2510
Sandeep
Thanks for marking my answer as helpful. Also mark appropriate answer as Correct so that others can also gets benefited from this in future and question will be removed from unsolved queue.
Abhijit
Community Rising Star 2022
By marking my response as correct or helpful, you contribute to helping future readers with similar issues.
Abhijit
ServiceNow MVP
Hi Raja,
Sandeep
Hi Sandeep,
I need to do automation for that I need to use Microsoft AD spoke, If I subscribe the Integration hub license, Can I get the Microsoft AD spokes free ?
Thanks in Advance!
Hi Raja,
Microsoft AD spoke  requires an Integration Hub subscription. For more information, see Legal schedules - IntegrationHub overview.
Note: This spoke is available as part of the family release. This spoke can be used to handle the computer objects.
Spoke requirements
Ensure that Active Directory Web Services (ADWS) is deployed in the same server where Microsoft AD is installed. See Microsoft documentation for information about deploying ADWS.
In the MID Server and Microsoft AD server, run these PowerShell commands to install the Active Directory module:
PS> Import-Module ServerManager
PS> Install-WindowsFeature -Name RSAT-AD-PowerShell
Sandeep
Hi Raja,
Any update to this ?Any follow-up required? if not
Kindly mark the answer as Correct & Helpful both such that others can get help.
Sandeep
