prerequisites for integration hub implementation ServiceNow
Raja27
I need to implement Integration hub can you help me on the prerequisites.
Thanks in Advance!!
Hi Raja,
Integration hub requires a subscription for production instances but can be activated on non-production and personal developer instances to build and test integrations without a subscription by activating a plug-in. The ServiceNow IntegrationHub Installer plugin activates a suite of plugins and takes about ten minutes to activate. You will receive an email from the Developer Portal when your plugin activation is complete. Once the plugin is activated, you can follow through the section to build your first spoke:
https://developer.servicenow.com/connect.do#!/event/knowledge2020/CCW2510
Sandeep
ShaliniJain
Need One clarification , is MID server installation mandatory for using Integration Hub and its related spokes or we can invoke Integration Hub related spokes and custom integrations to cloud applications without MID server as well.
Thanks & Best Regards,
Shalini Jain
