Problems with ForEach Item in Flow Designer when navigating a list type field (glide_list)
H_ctor Capdevil
Hello Friends,
I'm creating a Flow Designer, pointing to the documents table, but the problem is when I want to go through a List type field (glide_list) but the For Each Item node tells me that it's not allowed to go through a list.
Can someone help me?
Héctor 🙂
Matt Taylor - G
Giga Guru
Looks like this older Community post could be useful to you.
https://community.servicenow.com/community?id=community_question&sys_id=68b508dadb2c3bc0a39a0b55ca96...
Looks like you need a Get Catalog Variables Action to pull in the List, then a Look Up action to get the records for each sys_id in the list, and then a For Each Item action to iterate through them. Hope this helps!
