Record not found issue after submitting record producer
kalp
Hi ,
I have created a record producer for a custom table, i have found the issue that when i impersonate as other user and submit record producer form in portal, it is showing as record not found for the impersonated person who has not having admin role.
can someone provide solution to fix this.
Thanks in Advance,
kalyani
I hope you have a security admin privilege. If yes, can you go to the ACL and check your table name how many ACLs are created with that table. Disable those ACLs and try to do the same testing.
Please mark as correct answer and I hope, helped to identify the issue.
Suresh.
Suresh.
14 REPLIES 14
kalp
Actually, i do not have security admin role.
if we make inactive will it work.then i can ask and make it inactive, let me know, if i make inactive will it affect anything .
No it will not affect as this role is not used anywhere else
kalp
Thank you
No problem. Please try it and let us know if it is working
Can you get the role and disable the ACL
else
You should ask your team who is having required privilege to disable the ACLs.
Please mark as correct answer if it helped.
Suresh.
Suresh.
