Regarding Reference fields
Sanket Choughul
I have a couple of Reference Fields.If I click on the look up icon I want the data to be populated depending on some filters or query..and every user can see data depending on his category.
Ex.The caller field must show the data as per the logged in users department.
This must work on impersonation too.
Can I achieve this using OOB Functionality or can someone provide me how to do that.
Gaurav Shirsat
Reference Qualifier: - Reference Qualifiers are   to create filters that restrict the data that is returned for a reference field. A reference field stores a link (reference) to a field on another table, making the records/fields in the referenced table available to the form containing the reference field.
How to Reach Reference Qualifier: - Open any Table of Your Choice: - Incident/Problem/Change.
Step 1:-Application Navigator>Incident>Open Existing Record or Create New.
Step 2:-Right Click on Any Reference Field i.e. Caller, Service, and Configuration Item.
Step 3:-Configure Dictionary.
change the simple to dynamic in your case.
Dynamic Reference Qualifier:-Dynamic reference qualifiers enable you to use a dynamic filter option to run a query against a reference field to filter the returned data set.
call this script include into your dynamic reference qualifier.perform this activity for each field of your choice.
department:function()
var gr=new GlideRecord('sys_user');
gr.addQuery('sys_id',gs.getUserID());
if(gr.next()){
return "department"+"="+gr.department.toString();  }
refer the video
https://www.youtube.com/watch?v=6V1Vf-pk1wc&t=605s
Please Mark Correct and Helpful
Thanks and Regards
Gaurav Shirsat
Harish Vaibhare
Hi Sanket Choughule
Try these in the Default value field for the Variables:
javascript:gs.getUser().getRecord().getValue('department');//actual name
Kindly Mark helpful and correct if it works.
Thanks.
Hitoshi Ozawa
ServiceNow supports contextual ACL.  You can set up ACL depending on user's role.
https://docs.servicenow.com/bundle/orlando-platform-administration/page/administer/contextual-securi...
Gaurav Shirsat
if(gr.next()){
refer the video
Thanks and Regards
Gaurav Shirsat
Sanket Choughul
Thanks everyone for help!!
