script help with a business rule to prevent closing a problem if there are open child tasks
patricklatella
hi all,
I've build a couple similar business rules but am struggling with this one.   I have a related list of child tasks on our Problem records ([problem_task] table).
And what I'm trying to do is use "after" business rule on the [Problem] table to query the "problem_task" table to see if there are associated tasks, and then check their "state" field, and if the state on the child tasks is not one of the 3 complete states, to abort the closing of the parent Problem record.   Here is my script with comment notes.   thanks!
var prbNumber = current.number; //Problem number
gs.info('++++prbNumber1 is '+prbNumber);//this returns correctly
var gr = new GlideRecord('problem_task'); // This will be the child task table
gr.addQuery('problem',prbNumber); //field on the child table where the parent record number is = "problem"
gs.info('++++prbNumber2 is '+gr.number);//this returns undefined
if(gr.next()){
gs.info('++++state is '+gr.state);//this is not reached even if there is a record on the problem_task table with the "problem" field matching the prbNumber
if (gr.state == '3' || gr.state == '4' || gr.state == '7'){
  gs.addErrorMessage('Submission aborted, all associated tasks must be closed before this Problem record can be closed.');
//current.setAbortAction(true);
//current.state = previous.state;
})(current, previous);
Goran WitchDoc
Hi Patrick,
Without checking to deep into the code, I would say this line is the problem:
The problem field contains the sys_id of the problem, not the problem number
I would do something like this:
var prb = current.getUniqueValue(); //get sys_id
gr.addQuery('problem',prb); //field on the child table where the parent record number is = "problem"
gr.addActiveQuery();/Only want to look if there is active tasks
gr.setLimit(1);//Set limit to 1 since it only require 1 active task to abort
if(gr.next()){
Prateek kumar
This thread has your answer. Make modifications accordingly.
Close RITM if task is set to cancelled
juancarvajal
Is the "problem" field on the "problem_task" table a reference? If it is you have to change the query. You can use gr.addQuery('problem',current.sys_id); or if you already have the number use dot walk on the query. gr.addQuery('problem.number', prbNumber);
Thats the reason why it doesn't enter on the if(gr.next()) . Because there are not records using that filter.
Remember not to dot-walk like problem.number. That can be a major performance issue since it demands another server-call for each record it get.
Really?
I didn't know that. So it's better to not use dot-walk on queries?
