Setting current date and time in a Flow
Mahesh_Krishnan
OK.  I know this should be real simple but not getting the code to work.
I am setting a date field using a script instead of a data pill in one of the steps in a flow using the following code:
var invite_dt = gs.nowDateTime();
return invite_dt;
The system keeps resetting the above code to just GlideDateTime.
I have spent an hour figuring this seemingly simple task out and now reaching out to the experts here.
Thanks in advance!
Mahesh
Kieran Anson
If you're just wanting to set a field in flow to be the current time, GlideDateTime will work
You can even reference the community live stream
Mahesh_Krishnan
Kieran:
I have tried your code multiple times; it is just not saving it.  I am not sure if this is SN's way of saying that is bad code but that is what is happening.  I have no information on what is wrong.
Kieran Anson
Shubham Bongulw
Giga Guru
Hi Mahesh,
Use GlideDateTime() in your code.
The code should be like-
var invite_dt=new GlideDateTime();
return invite_dt.getDisplayValue();
Warm Regards,
Shubham Bongulwar
Please mark helpful or correct if it helps!!!
Mahesh_Krishnan
Phew..finally!  Thanks Kieran.  Thanks Shubham!
