SN Utils "Show Technical Names on page load" setting not working
Tommy SN Sahlin
Hi all,
I know this might not be the right forum, but I'll take a chance since I don't know where else to ask this. Also tagging @Arnoud Kooi @Arnoud Kooi in hopes of getting some super-help.
The setting ""Show Technical names on page load" has stopped working - it simply won't show Technical names.
Using command /tn works, but that's of course only while I stay in the current browser window.
My colleague has the same issue. I've checked that I have latest Chrome version, re-installed SN Utils, but no change.
Does nyone else recognize this, or know what the reason might be?
many thanks in advance  /Tommy
9 REPLIES 9
On Next Experience UI, I need to rework this function, (show on page load will not work here).
If this is a classic UI form, please add a detailed Issue with steps to reproduce on the GitHub repo
https://github.com/arnoudkooi/ServiceNow-Utils
This is indeed the Next Experience, thank you.
Which browser is the extension installed?
I know it should not be much related as most of the modern browsers are based on Chromium, but I'm using Brave browser and have no issues and I'm using also Next UI.
Hello, I'm using Chrome.
I'm using Brave browser and Mac OS (Sonoma), everything looks good.
Even double clicking a blank area of the form enables and disables the technical names (Thanks, Arnoud, that helps a lot during presentations!).
I'll try to test with Chrome in a virtual machine.
