Triggering a flow with inputs from a script?
Ivar Donado
Hi guys,
I’m currently working on enhancing a Flow I created a while ago. What I need to do is to be able to trigger it and set some parameters while I’m on it. I know SN provides the following methods:
  • executeFlow(flow name, inputs)
  • startFlow(flow name, inputs)
They seem to allow passing inputs as parameter, however I don’t see a way to configure or retrieve them in the Flow.
The context is: This flow will run all the ATF test suites, gather the results and send that info to the stakeholders. I created it and it works, however now we need to run two sets of suits: One for Chrome and one for Firefox to make sure all the client side stuff works correctly in those browsers. I wanted to re-use the flow by triggering it from a scheduled job and passing a parameter with the browser.
PS: While writing this question I realized that I might be able to save this flow as a subflow and trigger it from the script while passing the inputs as parameters. I’ll check if there are no repercutions to this.
Mark Roethof
Hi there,
executeFlow and startFlow are actually old deperecated methods. You could use:
Async:
var inputs = {
	'sysid' : '9d385017c611228701d22104cc95c371'
var result = sn_fd.FlowAPI
		  .getRunner()
		  .subflow(inputs)
		  .inBackground()
		  .withInputs(inputs)
		  .run();
Sync:
var inputs = {
	          .getRunner()
		  .subflow(inputs)
		  .inForeground()
		  .withInputs(inputs)
		  .run();
In this example I'm only providing a sys_id as input and expecting the subflow to contain a input "sysid".
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Can you tell me how should I configure the flow for this? I want the flow to be triggered when its called by the flow API in my widget and I want to pass the user email from widget to my flow. What trigger should I add?
