Turn off business rule during flow execution
Ravi117
I am updating multiple records thru flow designer. Since Business rules are set on the fields which are getting updated, i am not getting the expected results. please help on how to disable the business rules during the flow execution.
similar to setworkflow(false) used in Scripts.
Might be you misunderstood my solution.
The action I proposed will replace a regular "Update record" action, which will run with business rules.
If you are running a regular update record action, business rules will be run.
SR RAAKESH1
How can i send the SYS ID to the action from the main flow.
By creating an input on your action.
