UI policy and Client Script not working in native catalog view Service Catalog
Hi All
My instance version is Washington and some of the catalog item's client script, and UI policies are not working when I use 'Try It' (com.glideapp.servicecatalog_cat_item_view.do) from catalog item but the same works in Portal view. Could you please help with below queries ?
1) My customer's IT team still uses com.glideapp.servicecatalog_cat_item_view to raise request while the end users are using Portal. I suggested them not to use the native view at all. Does ServiceNow has any recommendations?
2) Multi row variables and some scripts are working in this view. Is that a technical limitation?
@Community Alums ServiceNow strongly recommends using Service Portal as the primary interface for catalog interactions because:
The platform continues to enhance Service Portal's capabilities, while the native com.glideapp.servicecatalog_cat_item_view is being phased out for new functionality.
Service Portal offers a more modern, responsive design that’s compatible across devices, whereas com.glideapp.servicecatalog_cat_item_view is not optimized for mobile.
Many new features, such as advanced scripting, multi-row variables, and catalog builder improvements, are designed specifically for Service Portal.
Certain client-side scripts and UI policies may not function fully or consistently in the native view, as they rely on Portal-specific APIs and framework adjustments.
you might want to encourage them to transition to Service Portal for future-proofing and to avoid functionality issues, as some features may not behave consistently in the native view.
@Community Alums - Could you please share if you have any documentation or KB article from ServiceNow ?
