Unable to activate workflow in flow designer
03-07-2021 09:53 PM
I have created 5workflows in flow designer.
they are in Draft status and I am not able to publish them
Two are activated and working fine but I am not able to activate rest 3.
I click activate and get a message that flow has been activated successfully but when I go back to the workflow list the value still appears to be false.
Please help.
Flow Designer
03-07-2021 10:47 PM
why not use Cart API to create REQ and RITM
Post that you can create Catalog Task by adding the logic to same script
03-07-2021 10:52 PM
Hi Ankur,
I have no idea how to do that ..Does that involve any coding/scripting?
I did not do any coding in this one.
Everything is working with above workflows, But I am not sure I am not able to activate three ...2 are activated and working fine.
03-07-2021 11:15 PM
okay with the above logic what is working till which part and what is not working
03-07-2021 11:39 PM
03-07-2021 11:43 PM
any error you see when you try to activate
