How to create SC task in a bi directional integration using flow designer integration hub?
tulasi8
How to create SC task in a bi directional integration using flow designer integration hub? Can anyone explain me in a step by step ?
Chaitanya ILCR
Giga Patron
Hi @Chaitanya ILCR ,
I am getting this below error
Ankur Bawiskar
@tulasi8
explore on Ebonding Spoke with less scripting
ServiceNow eBonding spoke
Refer the below link which has the approach with example shared by me.
Integration hub ebonding spoke
@tulasi8
Hope you are doing good.
