how to fix Transform map issue
meena eethakatl
Can some one help me why "Operatonal" field value not successfully ppulating when I did transform map.
Operational values populated based on Operation system, in Transform map Operational field successfully not updated.
Operational
Value : Window , Label Window Dependent Value :Windows 2000 Professional
Value : Window , Label Window Dependent Value :Windows 2003 Standard
Value : Window , Label Window Dependent Value :Hyper-V
in Transform map we are just using field mappings, no script being used.
Hi Tanushree Maiti,
I'm passing Operating System , Operational both columns data from excel sheet. is it because of Operational  has duplicate choice records with same value/label ?
