Issue with Split method
naveenbanda
I created a scripted rest api where I'm receiving sys ID's as query parameter
var sysID=request.queryParams.sysIDS.split(',');-- if I capturing like this , in logs I could see sysID and typeOf(sysID) is undefined.
If I removed split then it's fine and returning the values.
Sys ID which I'm passing : 46edaa6aa9fe198101b9d14ced16619f,46f09e75a9fe198100f4ffd8d366d17b
9 REPLIES 9
Goka Srinu
var param = request.queryParams;
 var sysID = (param.sysIDS) ? param.sysIDS : '';
if(sysID && sysID!=''){
var sysIDArr = String(sysID).split(",")
 Try the above code.
yashkamde
Hello @naveenbanda ,
I would recommend don't directly call .split(',') — check the type first. Your framework may already be parsing comma-separated query params into arrays.
var sysIDS = request.queryParams.sysIDS;
var sysID;
if (typeof sysIDS === 'string') {
    sysID = sysIDS.split(',');
} else if (Array.isArray(sysIDS)) {
    sysID = sysIDS;
    sysID = [];
gs.info('sysID: ' + sysID);
If my response helped mark as helpful and accept the solution..
Tejas Adhalrao
Hi @naveenbanda  ,
I would suggest not calling .split(',') directly. First check the data type.In some cases, the framework already converts comma-separated query parameters into an array.
var sysID;
sysID = sysIDS;
sysID = [];
Brad Bowman
Mega Patron
@Anurag Tripathi has the best approach, amidst a lot of unnecessary approaches.  You are trying to execute a string method - .split() - on a value that is not a string, as evidenced by your typeOf log, so just force the value to a string before you split and you'll be fine.
Thanks @Brad Bowman
