Need some help based on dependent field
12-24-2025 07:34 AM
Hello team, Merry Christmas
I need some assistance with an issue I’m facing. I have built a custom application where I created manager profiles across different tables. The username field is a reference to the sys_user table, while the remaining user details are already stored in sys_user.
I configured dependent fields using the Configuration/Builder approach. However, when I select a username to create a profile, the dependent fields (which are set to read-only) do not auto-populate or update as expected.
Could you please suggest possible solutions for this?
Specifically, I want the first name, last name, email address, and phone number to automatically populate and update based on the selected username. I also posted a table schema screenshot. Please suggest.
I’ve attached screenshots for reference.
12-25-2025 11:49 PM
Hi @x0x0 ,
Hope you're doing well! If this response answered your question, please close the thread by accepting it or feel free to ask any follow up questions.
