Not able to login to my instance.
SparshG
I'm not able to login to my instance. Here is what it shows:
Did 'reset instance password' many times but it still shows same error.
JaishreeR
Giga Guru
Hi @SparshG
Resetting the password multiple times throws error.  If you do not have much data try to release the instance and request for the new instance. Else if you wish to keep the same instance, use the last password that SN provided you by default before the reset.
Thank you
Jaishree R
