Issue in Notification body and who will receive
Pallavi Gawand1
Hi ,
I am triggering a notification but i am facing below two issues:
1. Notification is not going to 'Users/Groups in fields'.
2. Fields added in the Notification body is not displaying anything. See the screenshot attached
Please let us know if anyone has solution for it.
Thanks in Advance for the help.
Hemanth M1
Tera Sage
Hi @Pallavi Gawand1
The notification should be on the group table "sys_user_group" can you confirm??
Accept and hit Helpful if it helps.
Thank you,
Hemanth
Certified Technical Architect (CTA), ServiceNow MVP 2024, 2025
Hi Hemanth,
Yes the notification is on 'sys_user_group' table.
Hi @Pallavi Gawand1 ,
I have the same configs, its works . Have you selected the preview record??
Thank you,
Hemanth
did it resolve?
Thank you,
Hemanth
