Alternative solution for RP.getParameterValue()
11-06-2024 01:15 PM
com.glide.script.RhinoEcmaError: "RP" is not defined.
sys_script.e6ffde8fdbb54150c14aa90b8a9619e0.script : Line(12) column(0)
9: current.addActiveQuery(); //Keep it OOB
10: }
11: } else {
==> 12: if (RP.getParameterValue("sys_id") != "4f79f4ed1bf995108e576288bd4bcb68" || RP.getParameterValue("id") != "hrm_todos_page") {
13: current.addActiveQuery(); //OOB
14: }
15: }
Logs is throwing a warning so is there an alternative solution for RP.getParameterValue()?
11-24-2024 10:10 AM
Hello @Community Alums
In a Business Rule, you don't have direct access to RP.getParameterValue() since Business Rules execute on the server side and don't interact with URL parameters directly. However, you can use gs.action.getGlideURI() to retrieve parameters if the Business Rule is triggered during a user interaction where the URI is relevant.
Here’s how you can replace RP.getParameterValue() with gs.action.getGlideURI() in a Business Rule:
// User-specific behavior
if (gs.getUser().getID() === "cf34d4d41b12b410e2fedd79b04bcb0e") { // BTOps_UA_R
var glideURI = gs.action.getGlideURI().toString();
var isVariablePresent = glideURI.includes("1d15e5d71ba2f050e2fedd79b04bcbe0"); // Requestor variable sys_id
var refererHeader = GlideTransaction.get().getRequest().getHeader("referer").toString();
var isOffboardingCatalog = refererHeader.includes("4197ed721b1af410e2fedd79b04bcb7b"); // CSL Offboarding catalog item sys_id
if (!isVariablePresent && !isOffboardingCatalog) {
current.addActiveQuery(); // Default behavior
// Generic condition for other users
var glideParams = gs.action.getGlideURI();
var sysId = glideParams.get("sys_id");
var pageId = glideParams.get("id");
if (sysId !== "4f79f4ed1bf995108e576288bd4bcb68" && pageId !== "hrm_todos_page") {
})(current, previous);Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps others find the solution more easily and supports the community!"
Thank You
Juhi Poddar
Juhi Poddar
