Work Notes and comments are not showing in activity
02-03-2025 11:46 PM
Hello Team,
I have created a Custom table on custom application and added work notes and additional comments, Now added them to form with Activity formatter. But I am not able to see the Post button and I am not able to add the fields to activity filter as "Configure fields" option is not visible. I have created sys_property with table added the fields as well but still no luck.
02-04-2025 03:21 AM
02-04-2025 04:07 AM
@Community Alums
if your table extends task then only you can create formatter
How did you create that formatter?
If your custom table in scoped app doesn't extend task then you cannot add formatter, that's OOB behavior.
02-04-2025 04:29 AM
Hi @Ankur Bawiskar - Yes, My table is in scoped application and I have created a UI Formatter and added to the custom table will this not work?
02-04-2025 04:41 AM
@Community Alums
ok got it.
If the table is audited then it shows in the formatter form.
check this
Missing a POST button on some tables that extend off of table(s) which extends off task
02-04-2025 04:48 AM
@Ankur Bawiskar - I have already created new UI Formatter and added it for but still no luck, is something I'm missing?
