Work Notes and comments are not showing in activity
02-03-2025 11:46 PM
Hello Team,
I have created a Custom table on custom application and added work notes and additional comments, Now added them to form with Activity formatter. But I am not able to see the Post button and I am not able to add the fields to activity filter as "Configure fields" option is not visible. I have created sys_property with table added the fields as well but still no luck.
02-04-2025 05:22 AM
@Community Alums
can you try creating table using normal way and not using App engine studio?
02-04-2025 05:39 AM
02-04-2025 05:50 AM
@Community Alums
Hope you are in correct scope
If still not working then raise a HI ticket.
02-04-2025 06:59 PM
Yes, I am in the correct scope only but still no luck. Sure will raise a HI Case.
Thank you so such for your inputs.
Prudhvi
02-04-2025 07:08 PM
@Community Alums
I believe I provided enough information and help.
As part of this effort If my response helped please mark it correct and close the thread so that it benefits future readers.
Also do keep us posted about the HI case resolution.
