Help with SPM Reporting
10-18-2023 07:02 AM
Hi all,
I'm trying to create a bar report displaying our Top 10 Projects based on Approved Budget.
I've managed to create this report but now need to add additional bar columns for Actual spend and Expected final cost of the same Top 10 Projects.
So for each of the Top 10 Projects, there will be three bar columns:
1. Approved budget
2. Actual spend
3. Expected final cost
Any help would be greatly appreciated. I've attached a screenshot of what I've been able to achieve so far. I'm using the pm_project table.
Service Portfolio Management
10-18-2023 10:38 AM
Try using Stackby/ additional Group by and see if it meets the requirement.
Prashant
10-19-2023 03:59 AM
Thanks Prashant, I can't get it to work but I've marked your responses as helpful as I appreciate your help 🙂
