Inline script on flow designer.
Nihar1
Giga Contributor
Hello Team,
I am not able to achieve one logic. keep struggling to put the logic.
By using the flow designer I am able to create multiple task and associated the  task to one project.
The Requirment is depending on the project area (Custom field enabled ) I needs to populate the task assignment group.
Under the script I wrote bellow inline script .
But it is not returning any thing.
Here is the sciript.
It is always returning the else part value the if condition value is correct.
**Access Flow/Action data using the fd_data object. Script must return a value.
**example: var shortDesc = fd_data.trigger.current.short_description;
**return shortDesc;
var prjArea = fd_data.trigger.current.parent.u_project_area.getDisplayValue();
if(prjArea == 'Oracle EBS: Idea to Opportunity (I2O)'){
return'Approvers Project G1 Oracle EBS I2O';
}else {retun 'Approvers Project G1 Oracle EBS OBIEE';}
Is this within a scope other than global? gs.log can't be used in scoped applications.
I do not see it has any other scope.
I found the log by the way it is erroring in the inline script .
here is the log.
Operation(Project Flow.If$1.d9706bdc1bc3ecd04785964ead4bcb8b.11706bdc1bc3ecd04785964ead4bcbba.InlineScript_assignment_groupa970abdc66c3ecd03d384737bc1df80d) failed with error: com.snc.process_flow.exception.OpException: Error: Cannot convert null to an object.,Detail: Cannot convert null to an object.
at com.snc.process_flow.operation.script.ScriptOperationBase.handleScriptResult(ScriptOperationBase.java:54)
at com.snc.process_flow.operation.script.ScriptOperationBase.runScript(ScriptOperationBase.java:46)
at com.snc.process_flow.operation.script.ScriptOperation.run(ScriptOperation.java:64)
at com.snc.process_flow.engine.Operation.execute(Operation.java:106)
at com.snc.process_flow.engine.ProcessEngine.executeOps(ProcessEngine.java:386)
at com.snc.process_flow.engine.ProcessEngine.run(ProcessEngine.java:334)
at com.snc.process_flow.engine.ProcessAutomation.run(ProcessAutomation.java:57)
at com.snc.process_flow.engine.GlideProcessAutomation.runSync(GlideProcessAutomation.java:126)
at com.snc.process_flow.engine.GlideProcessAutomation.lambda$runAsUserSync$1(GlideProcessAutomation.java:213)
at com.snc.process_flow.engine.GlidePFSession.runPlanAsUserSession(GlidePFSession.java:26)
at com.snc.process_flow.engine.GlideProcessAutomation.runAsUserSync(GlideProcessAutomation.java:205)
at com.snc.process_flow.engine.GlideProcessAutomation.messageFlow(GlideProcessAutomation.java:242)
at com.snc.process_flow.engine.ProcessHubEventHandler.doSendMessage(ProcessHubEventHandler.java:284)
at com.snc.process_flow.engine.ProcessHubEventHandler.process(ProcessHubEventHandler.java:69)
at com.glide.policy.EventProcessor.processEventDuringNormalOperation(EventProcessor.java:213)
at com.glide.policy.EventProcessor.processEvent(EventProcessor.java:138)
at com.glide.policy.EventProcessor.process(EventProcessor.java:92)
at com.glide.policy.EventManager.processEvents(EventManager.java:291)
at com.glide.policy.EventManager._process(EventManager.java:166)
at com.glide.policy.EventManager.processDelegatedEvents(EventManager.java:140)
at com.snc.process_flow.engine.PFJob.execute(PFJob.java:17)
at com.glide.schedule.JobExecutor.lambda$executeJob$0(JobExecutor.java:108)
at com.glide.schedule.JobExecutor.executeJob(JobExecutor.java:111)
at com.glide.schedule.JobExecutor.execute(JobExecutor.java:95)
at com.glide.schedule_v2.SchedulerWorkerThread.executeJob(SchedulerWorkerThread.java:329)
at com.glide.schedule_v2.SchedulerWorkerThread.lambda$process$0(SchedulerWorkerThread.java:192)
at com.glide.worker.TransactionalWorkerThread.executeInTransaction(TransactionalWorkerThread.java:35)
at com.glide.schedule_v2.SchedulerWorkerThread.process(SchedulerWorkerThread.java:192)
at com.glide.schedule_v2.SchedulerWorkerThread.run(SchedulerWorkerThread.java:100)
"Cannot convert null to an object" somewhere in the chain of your dot walking a field doesn't have a value. Is u_project_area populated?
Hello Kieran,
I was able to got it through the GlideRecord on PM_PROJECT.
Thanks for pointing out the dot walking issue . It is not able to populated in that filed value.
So I decided to go through the GlideRecord route.
