Need Help with Platform Analytics Task Validation
MrKen
Hi all,
I’m working on the Platform Analytics Task, but it keeps failing validation despite multiple attempts. I’ve carefully followed the task instructions and recreated the dashboard and chart to match the example image at the end of the task.
The validation error I’m receiving is:
“Was a Pie Chart report created from the Priority field of all active incidents? Was there a new title for this report and was it saved?”
I can confirm that the answer to both is yes. My dashboard and chart look identical to the example, yet the task still fails. I’ve attached a screenshot showing both the dashboard/chart and the validation error.
Has anyone else run into this issue or found a solution? Any suggestions would be greatly appreciated.
Thanks in advance for your help!
Bhuvan
Giga Patron
@MrKen
Click on information icon of dashboard and change the chart title as per instructions 'Open Incidents by Priority'. In your dashboard, it is currently 'Incident Overview', change it accordingly. Save the dashboard and validate it.
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
21 REPLIES 21
I'm running into the same issue, only I notice on your graph, you've grouped them in the pie by state, not by priority, so there's no way that it should have worked for you....I'm going to try and run it so it's by State, but if that works then it means that the instructions in the lesson are wrong.  I can't figure this out and I've gone over it A LOT cuz this is driving me nuts.
It is no apparent that you use the Information Icon is how you get to the "Details" pane.
I am having the same issue. I have gone through the steps many times.
LibbyS
That didn't work.
DanitaD
Giga Contributor
The solution is not working for me. I have only been able to change it once but not in the order presented in the lesson.
