ARTICLE: How to fix a Subflow classified as Flow in Flow Designer
Options
11-16-2023 03:27 PM - edited 11-16-2023 06:50 PM
Issue:
When a Subflow is classified as Flow, it won't allow you to Activate / Publish the Subflow.
Steps to reproduce:
- Open Flow Designer
- Go to Executions
- Open execution record of any Subflow
- Click on Open Flow
- You will notice that this Subflow is classified as Flow
- Make some changes
- Save it (works fine)
- Try to Activate it, you will get the below error
Fix:
- Go to Flow Designer Home
- Close all tabs inside Flow Designer
- Go to Subflows
- Open a different Subflow
- Now go to FD home
- Then open the Subflow you want to modify
- Now it will be classified as a Subflow (which is correct)
- Make the required changes
- Save and Publish
Labels:
Flow Designer
- 660 Views
0 REPLIES 0
