Instance not waking up from Hibernation (dev205147). Please help revieve this instance
07-17-2025 01:14 AM
My instance is not waking up from hibernation. (dev205147). Please restore this instance for me.
07-18-2025 12:06 AM
Hello @anjanavalsa
Maximum days the PDI can be left inactive is 10 days, after that it is reclaimed.
If you're experiencing issues with your PDI, here are some important points to keep in mind:
Support Limitations: PDIs do not have official support, so the community cannot retrieve or recover your instance.
Instance Reset Option: You can release your current instance and request a new one, but this will erase all previous data.
To prevent data loss in the future, consider regularly backing up your PDI, especially for critical update sets.
Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps future readers to locate the solution easily and supports the community!"
Thank You
Juhi Poddar
Juhi Poddar
