Automatically create problem when more than 4 incidents with same CI, category & subcategory values
‎09-04-2024 06:18 AM
We are looking for a solution where system auto creates a problem ticket when there are more than 4 incidents are submitted for the same CI, Category and Subcategory combination , without redundancy.
Can this be achieved? Has anyone found a solution via Business rules or Flow Designer to achieve this? Need the solution run once every 10 days. Any suggestions or inputs please?
Thank you!
‎09-04-2024 11:32 AM
Hi @SanaPR
Try below BR:
var aggIncident = new GlideAggregate('incident');
aggIncident.addAggregate('COUNT');
aggIncident.addQuery('cmdb_ci', current.cmdb_ci);
aggIncident.addQuery('category', current.category);
aggIncident.addQuery('subcategory', current.subcategory);
aggIncident.query();
while (aggIncident.next()) {
if (aggIncident.getAggregate('COUNT') >= 4 && !aggIncident.problem_id) {
var prb = new GlideRecord('problem');
var prbID = prb.insert();
current.problem_id = prbID;
} else if (aggIncident.getAggregate('COUNT') >= 4 && aggIncident.problem_id) {
current.problem_id = aggIncident.problem_id;
To create Problem record set values accordingly and try this it should work.
Or can try similar code in Scheduled Job if you want to achieve it using Scheduled Job.
‎09-05-2024 04:09 AM - edited ‎09-05-2024 05:20 AM
Thank you for your response. Appreciate it very much. There seems to be couple of issues with this that I could correct with below code. But is there a way to link these 4 incidents to this newly created problem ticket? Also since it is an Insert/Update BR, it creates a new Problem ticket every time there is an update on one of the Incident records, But I needed it update since the category/subcategory/CI values may change even after incident ticket submission. Is there a way to check if a problem already exists for an Incident while updating the ticket and ignore creation of new problem if there is already one created/related.
Thank you for your reply.
Corrected script for After Insert Update Business Rule:
‎09-05-2024 12:09 PM
Hi @SanaPR
Yes, I just gave you sample where you can update details according to the requirement. To check Problem already exist or not also I added condition.
Do mark my answer as Correct if this helped you to resolved the issue.
‎04-24-2025 11:03 PM
sir, if my problem is close and then i got same CI issue so what should i do in that situation?
