05-29-2024 12:02 AM
Can someone help me how to display field backend values on a form?
Thank you
05-29-2024 12:17 AM
Hello @HarikrishH ,
This is the below link to add the SN util extension in your browser.
Please accept my solution and give thumbs up, if it helps you.
05-29-2024 12:18 AM
this doesn't come OOB from platform.
You need to install browser extension SNUtils for chrome.
05-29-2024 12:20 AM
Hi @HarikrishH ,
I hope only you wanted to see the backend values on the form & not for the end users/stakeholders. If yes there is a browser extension which allows you to see the backend values like the image you attached.
Extension link:
Once you installed the extension, double click on empty space on the form & the backend values will be visible.
If my answer helped you in any way, please mark it as helpful or correct.
