Catalog Variable that displays a users Direct and Indirect Reports
Sam Giles
I have a request for a catalog item that requires a field that references the sys_user table to display a managers Direct and also Indirect reports (No other users should appear). I've had no issues getting it to display direct reports with a reference qualifier but I can't figure out how to make it also display any Indirect reports.
I've tried using a script includes along with a client script but i'm not having much luck and all users are being returned.
This is the Script Includes which is Client callable and accessible from all scopes:
var GetUserReports = Class.create();
GetUserReports.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getReportUserIDs: function() {
        var currentUser = gs.getUserID();
        var reports = [];
        function getReports(managerId) {
            gr.addQuery('manager', managerId);
            gr.addQuery('active', true);
            while (gr.next()) {
                var id = gr.getUniqueValue();
                if (reports.indexOf(id) === -1) {
                    reports.push(id);
                    getReports(id);
        getReports(currentUser);
        return reports.join(',');
This is the Client Script which runs on load for the catalog item in question:
function onLoad() {
    var ga = new GlideAjax('GetUserReports');
    ga.addParam('sysparm_name', 'getReportUserIDs');
    ga.getXMLAnswer(function(response) {
        if (response) {
            var filter = 'sys_idIN' + response;
            g_form.setReferenceQual('direct_report', filter);
            g_form.setReferenceQual('direct_report', 'sys_id=NO_MATCH');
Any advice would be appreciated.
Thanks!
2 ACCEPTED SOLUTIONS
Ankur Bawiskar
@Sam Giles
so you want the direct manager rolling up to the next level and get all those users?
if yes then use this in advanced ref qualifier, no client script required
javascript: 'sys_idIN' + new GetUserReports().getReportUserIDs();
Script Include:
        var reports = [];
            while (gr.next()) {
                    reports.push(id);
                    getReports(id); // Recursive for indirect reports
        // Always include the current user too if needed
        // reports.push(currentUser);
        // Return as a comma-separated string
    // This is needed for GlideAjax
    type: 'GetUserReports'
@Sam Giles
the script I shared and the reference qualifier I shared should cover that scenario
Did you apply that and test it?
Example Scenario
Suppose:
You (manager) have 5 direct reports: A, B, C, D, E.
A manages 5 people: F, G, H, I, J.
B, C, D, E have no reportees.
Result:
The script will return sys_ids for:
A, B, C, D, E (your direct reports)
F, G, H, I, J (A's direct reports; your indirect reports)
Total: 10 users.
palanikumar
What do you mean by Indirect repartee's? Direct repartee's of the manager's repartee's?
You can update the condition of getReports function as below:
gr.addQuery('manager.manager', managerId);
The above condition can be updated based on number of levels
