Create multiple RITM based on data in MRVS using Flow Designer
iDNS
Hi, has anyone worked on creating multiple RITMs based on data from MRVS using Flow Designer & not via Workflow. I have tried to create record & also Submit Catalog which haven't been quite fruitful as expected. The ask is as below. Thanks in advance
  • Check the # of rows in the MRVS
    • If 1 record
      • Do nothing & process with the Flow
    • If more than 1 record
      • Create a RITM for each of the rows in MRVS  under the same REQ
      • Close the first RITM
12 REPLIES 12
@iDNS
something like this, please enhance
But remember for point 2 it will create fresh RITM and REQ and the newly created RITM won't be under same earlier REQ. If you wish to do then you will have to update the newly Created RITMs with the earlier REQ (S
I hope I provided enough information and guidance and you can easily enhance it as per your requirements with your developer skills
Thanks Ankur, this is where I was headed but Submit Catalog Item Request or Create Requested Item Record creates a new REQ & RITM which in turn sends notifications to Users causing confusion. I was inching towards creating a Custom Action that can take the data & create RITM under the same REQ but was lost.
Would you be able to point me in any direction that can create the RITM. Thanks
@iDNS
I already informed the same above in my earlier post that it's an OOB behavior and it will create new REQ each time.
Also I provided workaround to update the REQ on newly created RITMs
I won't suggest to create GlideRecord into RITM table as it's a request which has to be submitted.
You can ensure the OOB notifications don't trigger for newly created RITMs
Which notifications are you talking about?
OOB notifications are sent only when approval is asked for
I believe I have provided enough answer to your question and you can take it from here based on your developer skills.
@iDNS
Hope you are doing good.
@iDNS
