create one simple flow(using flow designer along with one approval)—>Sctask creation.
02-26-2025 08:00 AM
can someone helps me ,i have created the catalogue item and facing difficulty in creating flow. and how to add flow to the catalog item
02-26-2025 08:13 AM
Hi @mishrarakes ,
In catalog item (sc_cat_item) record, under Process Engine tab, you will find reference to attach a flow.
Additionally when a flow is created, you should add a trigger as Catalog item.
***If Correct/Helpful please take time mark as Correct/Helpful. It is much appreciated.***
02-26-2025 08:29 AM
it's easy and answer to your question can be found on docs
what's your challenge?
If you publish your flow then it should show under process engine.
