Else if not working in client script for state field
rmaroti
when state == null then no one reason field will be display.
could you please check below code:
else if(state == '')
g_form.setMandatory('u_in_progress_reason',false);
g_form.setDisplay('u_in_progress_reason', false);
g_form.setMandatory('u_new_reason',false);
g_form.setDisplay('u_new_reason',false);
g_form.setMandatory('u_cancelled_reason',false);
g_form.setDisplay('u_cancelled_reason', false);
g_form.setMandatory('u_on_hold_reason',false);
g_form.setDisplay('u_on_hold_reason', false);
g_form.setMandatory('u_closed_reason',false);
g_form.setDisplay('u_closed_reason', false);
g_form.setMandatory('u_resolved_reason',false);
g_form.setDisplay('u_resolved_reason',false);
Harsh_Deep
Hello @rmaroti
You can use this -
if(!state)
Mark Correct if this solves your issue and also mark 👍 Helpful if you find my response worthy based on the impact.
I have try it but not working still.
Amit Gujarathi
HI @rmaroti ,
I trust you are doing great.
Please find the updated code
function setFieldProperties(fieldName, isMandatory, isDisplayed) {
    g_form.setMandatory(fieldName, isMandatory);
    g_form.setDisplay(fieldName, isDisplayed);
if (state === null || state === '') {
    var fields = [
        'u_new_reason',
        'u_on_hold_reason',
        'u_closed_reason',
        'u_resolved_reason'
    fields.forEach(function(field) {
        setFieldProperties(field, false, false);
Was this answer helpful?
Please consider marking it correct or helpful.
Your feedback helps us improve!
Thank you!
Amit Gujrathi
Thanks for help but I'm in learning phase, so  i need to achieve this is only through client script even some other case also last else if or else is not working i want to know why this happened so please help me in that.
