Help in Client Script: If user belongs to CMDB assignment group, he can edit a field in cmdb table
ArushiG
Hi team,
Please help me with a client script on cmdb_ci_hardware table:
If a user belongs to cmdb_ci_hardware table, he should be able to edit the new field "External IP". I've written the below:
function onLoad() {
    var usrdetail = g_user.getUserID();
    var gr = new GlideRecord('sys_user_grmember');
    gr.addQuery('user', usrdetail);
    gr.addQuery('group', '47d86fe1db7f845055434cb11596192a');
    if(gr.next()){
        g_form.setVisible('u_external_ip',true);
        g_form.setReadOnly('u_external_ip', false);
    else{
        g_form.setVisible('u_external_ip',false);
        g_form.setReadOnly('u_external_ip', true);
13 REPLIES 13
@ArushiG
I have shared 2 approaches, 1st is ACL based (recommended) and 2nd is using onLoad client script + Display business rule
Please check the same below
Ankur Bawiskar
@ArushiG
2 Approaches
1) Field level WRITE ACL, use advanced script
answer = gs.getUser().isMemberOf('Group ABC');
2)  you can use onLoad client script + Display business rule on "cmdb_ci_hardware" to check if user belongs to particular group or not
    // Pass the result to g_scratchpad
    g_scratchpad.canEditExternalIP = gs.getUser().isMemberOf('Group ABC');
})(current, previous);
function onLoad() {
    // Check if g_scratchpad indicates permission to edit External IP
    if (g_scratchpad.canEditExternalIP) {
        g_form.setReadOnly('external_ip', false); // Enable editing
        g_form.setReadOnly('external_ip', true); // Disable editing
Thanks a lot Ankur, I'll go online in few minutes and will update after trying
@ArushiG
Sure do keep me updated !
