How to add Attachment to Existing Incident Record using Virtual Agent.
swaroop
Hello All,
In Virtual Agent I have created a topic, in which I should update an Incident with Attachment provided by end user in Chat Bot. I am using File Picker to Attach the file. I have tried using 'vaSystem.attacheRecord' and tried using script action and GlideRecord the 'sys_attachement' table. But it didn't worked. Can anyone suggest me how to update the Incident Record with provided Attachment in Virtual Agent.
Thanks & Regards,
S.Swaroop.
hi @swaroop ,
After the file picker use the script action as :
(function execute() {
vaSystem.attachToRecord(vaInputs.attachment, 'incident', vaInputs.select_incident);
attachment - is file picker variable
select_incident - is variable for incident
Please mark if helpful and accept it as solution
Akash
I just tried this and it works:
vaSystem.attachToRecord(vaInputs.file_picker.getValue(), 'table_name', 'sys_id of created record');
Hello Akash,
The script which I am writing and mentioned by you is correct and working, but mistake done by me was, I have placed script utility in the end. Now I have kept after file picker like said by you and it worked.
Thanks You So much.
Thanks & Regards,
S.Swaroop.
Can this also be done for RITM in the same code, or do I need to make a separate topic?
js20
Mega Guru
Is there solution for this? I am trying to save attachment selected by File picker into Case.
