How to create an HR Case using ATF in HR Agent Workspace?
iztgokul
Hi everyone,
I'm trying to automate a test case using Automated Test Framework (ATF) in HR Agent Workspace. The scenario involves impersonating an HR Agent, navigating to HR Agent Workspace, and creating an HR Case with specific values (service, category, description, etc.).
However, I couldn't find options like "Open Workspace" or "Open URL" that work with the HR Agent Workspace view in ATF. I want the case creation to happen specifically within the Workspace interface, not through the classic UI or GlideRecord.
Is it currently possible to automate HR Agent Workspace actions using ATF? Or are there any workarounds or supported approaches for Workspace-based testing?
Any guidance or best practices would be appreciated!
Thanks in advance.
J Siva
Hi @iztgokul
Use "Open a New Form" test step and select the HR Agent Workspace as a form UI.
Siva
Hi @iztgokul I think yes, we can.
kumaar
Can we add task to the same case ?
Ankur Bawiskar
@iztgokul
are you planning to use ATF for the "Case Creation" page which opens up from left navigation?
please share some screenshots.
