Read, write and report ACL will be created for assignment group type= IT Service
Pratiksha KC
I wants to create a Read, write and report ACL  for assignment group type= IT Service, Exception: Admin
When agent selects any other Category/Subcategory, but the ticket is assigned to a group of type: IT Service, the ticket should ONLY be visible for members of groups that have type: IT Service.
I have created a read and write ACL: incident.*
script -
answer = false; // Deny by default
// Always allow admin
if (gs.hasRole('admin')) {
  answer = true;
else if (current.assignment_group) {
  var group = current.assignment_group.getRefRecord();
  if (group.isValidRecord()) {
        if (group.getValue('type') == 'fb1b6d20c3612e1052a8f8bc7a01315c') {
      var gr = new GlideRecord('sys_user_grmember');
      gr.addQuery('user', gs.getUserID());
      gr.addQuery('group.type', 'fb1b6d20c3612e1052a8f8bc7a01315c'); // sys_id of type- IT service
      answer = gr.hasNext();
      answer = true;
2 ACCEPTED SOLUTIONS
Chaitanya ILCR
Giga Patron
Hi @Pratiksha KC ,
use deny Unless type acl or query BR for this
deny unless acl
replace itil with it services in the condition
script
answer = gs.hasRole('admin') || gs.getUser().isMemberOf(current.getValue('assignment_group'));
Chaitanya
Pratiksha KC
Thanks for the replies. @Chaitanya ILCR , @Ankur Bawiskar , @Rakesh18081
It simply worked with applies to condition. Got the solution.
9 REPLIES 9
@Pratiksha KC
if some ACL is allowing then your ACL even if blocks won't work
Ensure only 1 table level ACL is there and it's the one which you will work on
Rakesh18081
Try below code in Read ACL if this doesn't work try Query business and check access Analyzer to understand which ACL is providing the access to the user.
gs.getUser().isMemberOf(current.assignment_group) && current.assignment_group.group_type == 'IT Service'
Using Access Analyzer
If my response helped, please mark it correct and close the thread so that it benefits future readers.
Rakesh
Chaitanya ILCR
Giga Patron
Hi @Pratiksha KC ,
deny unless acl
script
Chaitanya
Pratiksha KC
Hi @Pratiksha KC ,
I have shared almost the same thing(deny unless type and condition)
if you feel that my post could be helpful for you in solving your issue
could you please mark it as helpful and accept it as a solution(you can accept multiple solutions 🙂)
Chaitanya
