10-22-2025 07:56 AM
Dear ServiceNow Community,
I have a query, If I have CSM and ISTM module, is it best to record any issues coming from customer as 'Case' only or to be captured as 'Incidents' too?
My understanding is anything with the service provider to be recorded as 'Incident' and all the customer facing ones should be 'Case'.
Please help with my understanding.What is ServiceNow recommended practice?
Thanks in advance.
Siddharth A
10-22-2025 08:20 AM - edited 10-22-2025 08:20 AM
Hi @Siddharth A ,
You can understand it as:
Use Case when you are dealing with a customer-facing issue (external customer, account relationship, warranty, install base, post-sales support) and the focus is on the customer conversation, entitlement, service / contract perspective.
Use Incident when the issue is an IT service disruption (whether internal or external) and the focus is on restoring the service, resolving the disruption, and minimizing business impact.
For more information, please refer to the following links:
Frequently Asked Questions to get you started with… - ServiceNow Community
Case vs. Incident: The ServiceNow Conundrum - Navigating the ITIL Maze
What is Customer Case Management? - ServiceNow
Differences Between a Case and Incident in ServiceNow? - ServiceNow Spectaculars
If my response helped, please mark it as the accepted solution so others can benefit as well.
01-19-2026 07:45 AM
No worries.
As per new community feature you can mark multiple responses as correct.
💡 If my response helped, please mark it as correct ✅ as well so that this helps future readers find the solution faster! 🙏
Hi @Siddharth A ,
10-22-2025 08:50 AM
Hi @Siddharth A ,
Differences Between Incident and Case Management in ServiceNow
- Purpose and Focus:
- Incident Management: Primarily aimed at quickly addressing and resolving unexpected disruptions or degradation in the quality of IT services. The focus is on restoring normal service operation as soon as possible to minimise impact on business operations.
- Case Management: Focuses on handling customer focused complex, issues that require detailed investigation and coordination.
- Process and Workflow:
- Incident Management: Typically involves a standardised, streamlined process with an emphasis on swift resolution. This process includes steps like incident identification, logging, categorisation, prioritisation, resolution, and closure.
- Case Management: Involves more complex, often customisable workflows that can vary significantly based on the type of case. It is not necessarily about quick resolution but rather thorough handling of the issue.
- Urgency and Impact:
- Incident Management: Deals with high-urgency situations where there is an immediate impact on business operations or service quality.
- Case Management: Often handles issues with right entitlements and contracts, where the impact is more on individual (consumer) or specific group (account) needs rather than on the entire business operation.
- Scope and Complexity:
- Incident Management: Generally addresses more straightforward issues with known solutions and procedures.
- Case Management: Tackles more complex situations that may not have a predefined path to resolution and could require cross-departmental coordination or in-depth analysis.
- Communication and Interaction:
- Incident Management: Communication is often status-oriented, focusing on the progress of incident resolution and restoration of service.
- Case Management: Involves more extensive interaction with customer, often with a need for detailed information gathering, continuous updates, and personalised communication.
- Integration with Other Processes:
- Incident Management: Closely integrated with other ITSM processes like Problem Management and Change Management.
- Case Management: May involve integration with broader business processes, including external departments or entities, also companies involved in IT Support (MSPs) can use underlying Incident, Problem and Change Management processes.
- Examples:
- Incident Management: Server downtime, application errors, hardware failures.
- Case Management: Specialised service requests, complex customer inquiries, internal process exceptions. Of course IT Support companies can make use of the Cases as an Incidents with the First time fix.
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
