Virtual Agent issue in Portal and how to locate the configuration
06-07-2022 12:40 AM
Dear all,
I am creating a Virtual Agent through Agent Chat and put it in the specific portal, it works well.
But when I typed something in the search bar and go into a new page, the Virtual Agent icon in the lower right corner disappeared:
When clicking Chat, the Virtual Agent reappeared, and the conversation inside was completely different from (the one in Home page) what I had set up.
I would like to know how this effect is achieved and if I want to find out why, where should I go to locate this configuration?
Virtual Agent
06-08-2022 02:27 AM
Changing the conversation would not fix your issue of the Virtual Agent icon not visible?
Anyway, if it's just the conversation you are after:
Instance Option
Or
Kind regards,
Mark
2020-2022 ServiceNow Community MVP
2020-2022 ServiceNow Developer MVP
06-08-2022 02:30 AM
Can I find this topic in Virtual Agent Designer?
06-08-2022 02:32 AM
You just enter the topic you want in the Instance Option.
Kind regards,
Mark
06-08-2022 02:35 AM
06-09-2022 08:13 PM
Hi
Do you know the next step?
Thank you.
