Virtual Agent issue in Portal and how to locate the configuration
06-07-2022 12:40 AM
Dear all,
I am creating a Virtual Agent through Agent Chat and put it in the specific portal, it works well.
But when I typed something in the search bar and go into a new page, the Virtual Agent icon in the lower right corner disappeared:
When clicking Chat, the Virtual Agent reappeared, and the conversation inside was completely different from (the one in Home page) what I had set up.
I would like to know how this effect is achieved and if I want to find out why, where should I go to locate this configuration?
Virtual Agent
06-09-2022 09:17 PM
Hi there,
Just simulating this. Although there is this instance option, the widget is not really behaving like it.
Looking further in the widget code:
So actually, upon clicking Chat, the branding record is applied (looks correct) + if VA for Universal Request is applied then the instance option would work. Though if you don't have that plugin active, the Instance Option is useless.
Kind regards,
Mark
2020-2022 ServiceNow Community MVP
2020-2022 ServiceNow Developer MVP
06-10-2022 03:19 AM
Hi
Thank you for your reply. Sorry for the delay in email notification.
I actived the com.snc.universal_request.va and tried again:
Well, I think the topic was switched by the plugin, However, I tried to fill in my own topic in the instance option, but it still did not take effect.
I still have two remaining problems:
1. Where does the topic of this new VA come from? Can I find it in Virtual Agent Designer? How can I modify its conversation content(eg I can find its flow and modify it)?
2. Here we can only use the preset conversation template of the plugin? Can we switch to any of our own topics?
