Automatic role assignment using flow designer
BKulisz
Hey Team,
Is there any possibility to assign the specific user role automatically using Flow Designer?
I have very simple flow where after request approval, user should get the new role assigned automatically.
Can you advice?
Thanks in advance!
PrashantLearnIT
Tera Sage
Hi @BKulisz
You can do that.
Hey @PrashantLearnIT ,
Thank you for your quick response 🙂
Can you guide me a little?
I was trying to search the proper action but don't know how to proceed...
Hi @BKulisz
You can use Create Record action in flow, and then you can create record in sys_user_has_role.
