Need Help Creating Records for Each Updated Incident Field Using Flow Designer
Pratiksha Kalas
I need some guidance on implementing the following requirement using Flow Designer.
Whenever an Incident is updated (for example, State, Assignment Group, or Description), I need to create a separate record in a custom table (xyz) for each field that changed.
For example, if the following three fields are updated in a single Incident update:
  • State
  • Assignment Group
  • Description
Then 3 records should be created in the xyz table, with the following details captured for each changed field:
  • Field Name
  • Old Value
  • New Value
  • Updated By
  • Updated Time
I am currently trying to achieve this using Flow Designer with the following setup:
  • Trigger: Incident  Created or Updated
  • Using the Changed Fields object available in the trigger
However, I am not sure how to use the Changed Fields collection to iterate through all modified fields and create separate records with the old and new values.
Has anyone implemented a similar requirement using Flow Designer? Any guidance or examples would be greatly appreciated.
Thank you in advance.
Ankur Bawiskar
@Pratiksha Kalas
check this
Flow Designer: Changed Fields
Using the data within the "Changed Fields" Pill
Ankur Bawiskar
@Pratiksha Kalas
check this
