Diagram Flow not displaying anything
JLeong
Hi Guys,
First, the Diagram Flow was grayed out because of the following error:
So I removed the Error Handler, and then it let me toggle between the 2 views, however the Diagram is empty:
Am I missing anything?
Thank you!
JLeong
Yes, this issue is fixed in Washington!!!
12 REPLIES 12
You're absolutely correct. ServiceNow mentions in the workaround KB you need to execute the script in the Flow Diagram scope otherwise it won't work. I just created a Fix Script in that scope and then executed it in the background. Completed near instantly and worked like a charm.
Adam43
thank you gentlemen- I actually used Xplore tool to run the script in scope and it worked.  I now have my diagram showing up!
Josh Pirozzi
Per NowSupport - If you're still on Vancouver, this is a Known Issue and Patch 9 will provide a fix to the view.
