Flow Designer Help for Retrieving Records
Wendy Peterson
Giga Guru
I have a table that I created called Telecom Renewals which has a field called "Expiration Date" I want to be able to send out a notification 30 days before that is due. I found an article on here that suggested "Look Up Records" which I did. But when I go to do the "For Each Item" it turns Red. I also tried doing the look up on the side of that. Any idea's on what I am doing wrong? I was going to do a daily run to have it look for any that have the expiration date 30 days from now. TIA - Sorry new to flow designer.
Joe S1
Hi @Wendy Peterson
On your Step 1 where you're performing the lookup make sure it's a "Look Up Records" with an "s" and not a "Look Up Record"
Joe S1
Hi @Wendy Peterson
OMg Thank you I looked at thing a thousand times trying to figure out what i was doing wrong. That was it.
