Flow designer unable to see flow execution
SNow35
Giga Guru
I am trying to create some flows and tried to test via flow designer but when I click on 'Your test has finished running. View the subflow execution details' . I am getting screen as attached but  I need to see the execution details. I have tried to change the properties 'Level of reporting data generated by the flow engine' to 'all configurations and run time values' but getting same screen when checking execution details. Currently I have tried in washington instance.
3 ACCEPTED SOLUTIONS
Mark Roethof
Hi there,
Follow what @Zach Koch mentioned. If that's not the issue: update the Store application for "Workflow Studio".
Navigate to Plugins and Search for Workflow Studio:
And the Update it or schedule it:
11 REPLIES 11
Zach Koch
No screenshot is attached. Can you confirm that you also have the system property, com.snc.process_flow.reporting.level, turned on along with the flow itself's property for reporting turned on?
@Zach Koch  Thank you for your response. I have turned the properties which you have specified but I am facing same issue.
Nilesh Pol1
Giga Guru
@Nilesh Pol1 Thank you for your response. I have checked the urls you have shared. Can i know how to install workflow studio in PDI ?
